IPCC Not Ready code
jowenjowen3
Where do I add a new Not Ready reason code?
Brandon Buffin
Open Desktop Administrator from Start -> Programs -> Cisco -> Desktop -> Desktop Administrator on the CRS server. Drill down to Desktop Configuration -> Reason Codes. From here you can configure Logout and Not Ready reason codes.
Hope this helps. If so, please rate the post.
Brandon
8 Replies 8
muhammmad.rehan
which IPCC you are using?
IPCC express
or ipcc enterprise
Express
Remember, that reason codes are systemwide. once you enable it, regardless of how many call center groups you are running off the IPCC server, every body will have to use reason codes.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
There are two ways you can use the reason codes,
1: Already mentioned that you can use the system default reason codes
2:When we integrate the Cisco Agent desktop with the database like oracle siebel etc, then we can define our own Wrapup codes in the database which the agent can use when the call ended.
Brandon Buffin
Brandon
Do you know where the Reason Codes get stored when you define them?
I would assume this would be in the database (SQL)
Sankar Nair
I looked in the sql dbs. The only place I see it is in the db_cra db in the agentstatedetail table. It is used there to show the reason code for the state changes by the agent. That is not what I am looking for.
I want to know where the reason codes original values are stored.... if a user adds a new reason code in the Desktop Administrator..where is it stored?
If anybody knows where they are defined I would appreciate it.
