CSA Agent disabling
Apr 18th, 2007
Is there a way to have the CSA agent service automatically start-up if an administrator stops the service?
I know if an administrator logs in and stops the service and then logs out the service will start when the user logs out and back in.
Overall Rating: 3 (1 ratings)
tsteger1 Wed, 04/18/2007 - 17:12
You can't use a CSA Service Restart rule for obvious reasons and modifying the Service Host Manager parameters did not seem to work either.
If you are concerned, you may want to consider removing the ability to stop the agent service from all but a few administrators.
