Callmanager Process Memory Threshold?
Apr 18th, 2007
  • Bronze, 100 points or more
I'm working on trying to define what an appropriate "warning" threshold should be for the CM process (4.1.3) using NetIQ. The default is like 35MB which is obviously too low, but even setting it much higher, it keeps getting triggered. Has anyone come up with a threshold for the CallManager process memory utilization that they've found to be effective?
On a related note, say the threshold is X megabytes and I hit it...is there any way to reduce the memory in use when the server's running besides stopping/starting the service or a reboot?
Any help would be greatly appreciated,
Jim
Aaron Harrison Thu, 04/19/2007 - 01:30
  • Community Spotlight Award,
    Member's Choice, May 2015
Hi Jim
The CM service does a lot of things... the amount of memory it consumes will depend on a lot of things (besides bugs :-)) such as the number of phones on your system, how busy the system is, number/type of gateways, and lots of other things... so there won't be a 'typical' memory usage.
I'd make a judgement on what is the daily/weekly peak, and add a good amount for variance and growth.
Aaron
