how does EoMPLS know tunnel ready?
Apr 18th, 2007
EoMPLS VC will be declared up when there is a MPLS LSP (assume we are talking about LDP) to remote and VC label (and other parameters) are negotiated, my question is how does EoMPLS know tunnel is ready? IOS LDP use independent control, which means even local router has a label mapping for the destination loopback prefix, it is not guaranteed that a label switched path exits end to end. So how does EoMPLS know tunnel LSP is ready or not? does it do a mpls ping internally to verify the LSP?
Overall Rating: 4 (1 ratings)
swaroop.potdar Wed, 04/18/2007 - 20:19
  • Blue, 1500 points or more
1) When you configure an ingress interface on a PE for L2Transport, the PE allocates a new label called VC label and binds it to the configured VCID.
2) Now this VC Label to VCID binding is exchanged over the directed LDP session with the remote end PE. This goes as a Label Mapping Message,
3) when each PE receives the message, they try to match the message value with the VCID configured locally. If it matches both sides the VC state comes to an established state.
4) And the Label values received in the process are used to switch data for that particular VC.
5) Now since the whole exchange of VC labels takes place over already existing MPLS domain,
the LSP is place when the exchange happens. If the LSP is not in place between the 2 PE's then the exchange would never happen. So it really doesnt matter what label distribution mode is used by MPLS, as if the IGP labels are not available end-to-end the VC labels cannot be exchanged. (This is why we get and have a label stack for ATOM, one is the outer IGP Label, and then the inner VC label, which is exchanged over the existing MPLS IGP Labels)
Now the MPLS LSP Ping/Traceroute or VCCV are methods used to do operation and management of L3 and l2 VPN's after they are deployed to verify and manage their end-to-end connection state.
HTH-Cheers,
Swaroop
jiangu Wed, 04/18/2007 - 20:37
I don't think you answered my question, my question is how does EoMPLS know end-to-end LSP exists? distribution mode matters because if IOS uses ordered distribution, local router can safely claim end-to-end LSP exists as long as it receives the label mapping from downstream.
And why the whole exchange of VC labels have to take place over already exisiting MPLS domain? VC label exchange happens over a targted LDP session which is just a TCP connection, you can use L2TP encap for transportation, right?
swaroop.potdar Wed, 04/18/2007 - 22:37
The original post was about the VC being ready. When the VCID with VC labels are exchanged on both sides the VC is ready.
And since the question was with LDP and MPLS, the answer revolved around Tunnel Label (IGP Label from the existing MPLS domain). Its although not mandatory, since as per the PWE3, other modes or transport can be used like L2TP PW.
And coming to your additional question, yes using independent control, in some rare conditions it may happen that the End-To-End LSP is not really there (broken in between, although I havent experienced this in real life), in that case we have to use the OAM (LSP Ping/Traceroute with VCCV capabilities) to verify and correct the same.
Hope it answers your question.
HTH-Cheers,
Swaroop
jiangu Wed, 04/18/2007 - 22:42
Thanks a lot for your explanation, Swaroop. I found that if end-to-end LSP is broken in between, EoMPLS session won't come up, so still my original question, how does EoMPLS know?
Harold Ritter Thu, 04/19/2007 - 06:29
  • Cisco Employee,
Unless the ingress PE is directly connected to the egress PE, the VC should come UP even if the LSP has not been signaled end to end for some reason.
A case of imcomplete LSP is most likely due to misconfiguration (LDP not configured on one of the LSRs, label filtering wrongly configured, etc) and can be troubleshot using MPLS ping and traceroute.
For more information on MPLS ping and traceroute, see the following document:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120limit/120s/120s27/gslsppt.htm
Hope this helps,
