H.323 Gateway on CCM 4.2(3)
Apr 18th, 2007
Can someone drop me a sample configuration for an h.323 PSTN gateway?
We have a 2821 with 2 4xFXO ports on it. I have configured the gateway as per various examples, I can dial out, however dial in the system get's a fast busy as soon as the system answers (if i use connection PLAR) or I get constant ringing (if I use connection PLAR opx)
In traces the most I can see is some sort of an h.323 reason code 21.
I would simply use MGCP -- however the customer has CallerID
Any thoughts?
Overall Rating: 3 (1 ratings)
kelvin.blair Wed, 04/18/2007 - 19:24
  • Silver, 250 points or more
You need to make sure you bind the h323 traffic to an interface. For example;
interface faste 0/0
ip address X.X.X.X
h323-gateway voip interface
h323-gateway voip bind src X.X.X.X
Once that is done, you need to configure it in call manager as a h323 gateway with the correct CSS for inbound calls.
The next thing is to configure your dialpeers and voice ports. Here is an example. All calls from FXO port 1 should go to extension 3000. This extension 3000 is either a shared line or huntgroup in CM. Here is the basic voice-port configuration:
voice-port 0/0/0
connection plar 3000
caller-id enable
Now a dialpeer needs to be setup to match the extension that is being dialed so that it can be forward to Call Manager.
dial-peer voice 3000 voip
destination-pattern 3000
session target ipv4:X.X.X.X
dtmf-relay h245-alphanumeric
codec g711
no vad
and that is it. But again MAKE SURE CM GATEWAY DEVICE CONFIG FOR INBOUND CALLS is placed in the right CSS or else you get a fast busy no matter what you do.
If that doesn't help, please post your config. It will help in solving your issue.
If this post was useful, please be sure to rate it.
justincohen Wed, 04/18/2007 - 20:04
So far everything you say matches what i've been doing. That config matches mine exactly.
I've bound the interfaces, and confirmed through sniffer and traces that it's sourceing the traffic from the correct IP.
The CCS is correct -- it's the same assigned to another telephone -- and it can call the DN no problem.
ip domain name ABC.com
trunk group PSTN
description PSTN ACCESS
hunt-scheme sequential both up
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 2
call start slow
interface GigabitEthernet0/0
description MPLS CKT# aaaaaaaaaa
bandwidth 10000000
ip address x.x.x.x 255.255.0.0
duplex auto
speed auto
interface GigabitEthernet0/1
description LocalVlanAccess
no ip address
duplex full
speed 100
interface GigabitEthernet0/1.111
description DataVlan
encapsulation dot1Q 111
ip address x.x.1.1 255.255.255.0
interface GigabitEthernet0/1.112
description VoiceVlanWired
encapsulation dot1Q 112
ip address x.x.2.1 255.255.255.0
ip pim sparse-mode
h323-gateway voip bind srcaddr x.x.2.1
router eigrp 1
redistribute static
network x.x.1.0 0.0.0.255
network x.x.2.0 0.0.0.255
network x.x.0.0 0.0.255.255
no auto-summary
voice-port 0/0/0
trunk-group PSTN
timeouts call-disconnect 3
timeouts wait-release 3
timing hookflash-out 500
connection plar 6012
description 905-1234567
caller-id enable
voice-port 0/0/1
trunk-group PSTN
caller-id enable
voice-port 0/0/2
trunk-group PSTN
caller-id enable
voice-port 0/0/3
trunk-group PSTN
connection plar opx 6012
caller-id enable
dial-peer voice 13 pots
trunkgroup PSTN
description 10 Digit Dialing
destination-pattern 9[2-9].........
forward-digits 10
dial-peer voice 15 pots
trunkgroup PSTN
description Noth American Long Distance
destination-pattern 91[2-9].........
direct-inward-dial
forward-digits 11
dial-peer voice 16 pots
trunkgroup PSTN
description International LD
destination-pattern 9011T
forward-digits all
dial-peer voice 600 voip
destination-pattern 60..
session target ipv4:x.x.2.3
codec g711ulaw
dial-peer voice 601 voip
session target ipv4:x.x.2.2
codec g711ulaw
kelvin.blair Thu, 04/19/2007 - 05:04
Change the following information
trunk group PSTN
voice-card 0
dspfarm
voice rtp send-recv
voice service voip
h323
voice class h323 1
call start fast
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
bandwidth 10000000
duplex auto
speed auto
no ip address
duplex full
speed 100
ip pim sparse-mode
router eigrp 1
redistribute static
no auto-summary
voice-port 0/0/0
trunk-group PSTN
caller-id enable
voice-port 0/0/1
trunk-group PSTN
caller-id enable
voice-port 0/0/2
trunk-group PSTN
caller-id enable
voice-port 0/0/3
trunk-group PSTN
caller-id enable
trunkgroup PSTN
forward-digits 10
trunkgroup PSTN
direct-inward-dial
forward-digits 11
trunkgroup PSTN
forward-digits all
voice-class h323 1
voice-class codec 1
no codec g711ulaw
preference 1
voice-class h323 1
voice-class codec 1
no codec g711ulaw
Run these debugs to be sure the call is going to ccm.
debug voip dialpeer inout
debug voice dialpeer inout
debug voice ccapi inout
debug cch323 h225
debug cch323 h245
Do a detailed CCM trace and look for the extension that is being called.
justincohen Thu, 04/19/2007 - 06:50
Thanks for your help Kevin.
I will do those tests and get back to you, unfortunatly the customer has to sit on MGCP for now - until we can work this out, so i have to do these test in the evenings (EST)
tahiryasin Wed, 08/15/2007 - 18:02
I have the sxact same situation 2811 with 4FXO and in bound gets a fast busy ? Did Anyone solve this issue.
