Input errors
Apr 18th, 2007
I have a 2811 with the latest IOS on it and my interface FA0/0 is constantly counting up input errors.
I have changed the cable set the speed and duplex and tried auto for both sides. There are no errors on the switch, but I changed the port on the switch just for fun. :)
Here is my show interface fa0/0
Router#sh inter fa0/0
FastEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 0014.f201.5be0 (bia 0014.f201.5be0)
Description: $ETH-LAN$Router interface
Internet address is
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 22/255, rxload 6/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:26:07
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2364000 bits/sec, 1828 packets/sec
5 minute output rate 8649000 bits/sec, 1552 packets/sec
2949726 packets input, 543040449 bytes
Received 14995 broadcasts, 0 runts, 0 giants, 0 throttles
3559 input errors, 0 CRC, 0 frame, 0 overrun, 3559 ignored
0 watchdog
2491240 packets output, 1725241583 bytes, 0 underruns
0 lost carrier, 0 no carrier
Any idea what this could be or should I even worry about it?
ariela Wed, 04/18/2007 - 22:28
Ignored packets are those that are discarded because the interface hardware does not have enough internal buffers. Broadcast storms and bursts of noise can result in an increased number of ignored packets. Check your traffic using a SPAN port.
