HIGH PROCESS UTILIZATION
Apr 18th, 2007
HI Friends,
From last two days i am finding a new develpment in my network. I have a 7206 with around 8 E1 links and 2 DS 3 terminated on it. I am getting huge latency when i am pinging from the router to the other end interfaces. Its also very slow when i give the "show run" command. When i checked the CPU process Utilization, it was peaking to as high as 98 % and this is only when either i ping from the router of when i give "Sh Run". If i issue a ping from LAN to LAN their is no delay and no effect on the Process Utilization.
Could you please help me with a solution for this problem?
Awaiting eagerly.
Regards, Vamsi Krishna
spremkumar Wed, 04/18/2007 - 23:11
  • Red, 2250 points or more
Hi Vamsi
Its time to check your interfaces for traffic utilisation and also check which process is hogging up the cpu.
do post the output of both show interface and show process cpu here..
regds
