OSPF path selection issue
Apr 18th, 2007
My question is if an OSPF router learns a network from two different paths. One with a higher cost but it is a intra-area route. The other one with a lower cost but it is a inter-area route. It turns out the route choose the first one with a higher cost. Is this how it supposed to be? or it should always choose the one with a lower cost regardless of the route type?
Andrew
Overall Rating: 4 (1 ratings)
Jon Marshall Wed, 04/18/2007 - 23:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Andrew
Once OSPF has selected the longest match to the specific destination address which in your case you end up with 2 matches, the Intra area route and the Inter area route, it then uses the path type in the route selection process. In order of preference
1) Intra-area
2) Inter-area
3) E1 external
4) E2 external
So yes OSPF will choose the Intra-area route over the Inter-area route.
Jon
ariela Wed, 04/18/2007 - 23:25
  • Silver, 250 points or more
Hi Andrew,
Intra-area OSPF routes are preferred over inter-area routes regardless of the cost.
Andrea
mounir.mohamed Thu, 04/19/2007 - 00:39
  • Gold, 750 points or more
Dear Andrew,
The OSPF routing process shall compare between any equal costs routes with the same area type, so if you have one Intra-area route to specific destination and another Inter-area route to the same destination, Regardless the cost the router will select the Intrea-area route over the inter one, because it's logic to keep the traffic within the area instead of send it out the area,
Also the below list shown the OSPF routes checklist:
1) Intra-area (To keep the traffic internal)
2) Inter-area (Prefered over External)
3) E1 external (Over E2 because the cost to the ASBR counted)
4) E2 external
Please rate helpful posts.
Best Regards,
Mounir Mohamed
