Warning message
Questions about 3750 stack
Apr 19th, 2007
  • Blue, 1500 points or more
Hi All,
Could someone explain to me the following regarding 3750 switch stack technology
1. Will the master do all processing (i.e. routing, packets travels to ports of all member switch) or it will be distributed to all member switch in the stack?
2. If I have two member switch in a stack and currently in production, can I add two more without affecting the operation of these two member switch in production?
TIA
Craig Balfour Thu, 04/19/2007 - 00:20
  • Bronze, 100 points or more
For a good overview of the behaviour of Catalyst switch stacks see "Understanding Switch Stacks" in Managing Switch Stacks at
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00801a6558.html
1. The master is responsible for a lot of the processing but not all of it.
2. You can safely add more units to the stack without effecting the operation of the stack.
desai.jaideep Thu, 04/19/2007 - 00:32
  • Gold, 750 points or more
(1)Yes its done my master.
(2)Sure you can.
JD
