Collin Clark Thu, 04/19/2007 - 07:32
  • Purple, 4500 points or more
No it does not, you'll have to report traffic flows from the router before or after the firewall.
HTH and please rate.
a.batuyeva Thu, 04/19/2007 - 18:42
Could I count traffic with the help of mirroring port on a Catalyst 4503?
a.batuyeva Mon, 04/23/2007 - 18:33
Ben, the softflowd generates netflow traffic to a server that collects it, does it?
Do you know whether I can install the 1720 instead the linux server with softflowd?
Collin Clark Fri, 04/20/2007 - 05:29
Do you have a layer 3 supervisor in the 4503? If you do, post what it is and then we can tell you if you can use it for netflow.
a.batuyeva Sun, 04/22/2007 - 18:29
Yes, I have the layer e supervisor II+TS. But I know, that it doesn't support NetFlow.
I thoght about spanning the port to a spare interface. I have two opportunities: to use a linux host or an old router 1720 (it's not used in our network). Is it possible to use the 1720 as a netflow agent in this situation?
Collin Clark Mon, 04/23/2007 - 06:00
I have never done it that way, but if you look at Bens post he has.
