Tag a incoming call
Apr 19th, 2007
We do have IPCC 4.0 and wonder if there is way to tag incoming call. we have range 1000-1020 for company A and range 1050-1070 for company B. lets say user call 1001 and it should be Alpha tag with company A.
Any thoughts how to achieve in IPCC.
l.mourits Fri, 04/20/2007 - 12:00
How about this?
- use Get Call Contact info to get the "called number"
- use IF or SWITCH to determine the case
- then use Set Session info to write the tag to a custom field
(see the link below for an example of the Set Session)
- if you like you can even use Administrator Desktop to create a new workflow layout with custom field and show this in enterpirse data popup
shahid.ikram Sat, 04/21/2007 - 10:04
Thanks Leo,
Bit lost, could you pls drop an example that would be great also you are missing the link you have mentioned above.
