VIC-2BRI-NT/TE BT Dialpeers
Answered Question
Apr 19th, 2007
I am trying to configure my cisco CME to use my BT ISDN connection. I have attached the configs. When I try and dial out, by pressing 8 then the number.
(destination pattern set to 8.T) I get an unknow number error on the phone. When I debug the dial peers it says no dial peer matched.
Can anyone help me?
Correct Answer by Aaron Harrison about 10 years 1 week ago
If you have a BT ISDN why do you need to emulate the network side of the connection?
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn layer1-emulate network
isdn protocol-emulate network
Is your ISDN even up at this point? If not, the dial-peers will go down as well.
Do a show isdn status, and post the result.
Also a show dial-peer voice summary.
Aaron
Overall Rating: 4 (2 ratings)
Correct Answer
Aaron Harrison Thu, 04/19/2007 - 03:15
  • Community Spotlight Award,
    Member's Choice, May 2015
interface BRI0/0/0
no ip address
Aaron
martinbuffleo Thu, 04/19/2007 - 03:40
Thanks for your reply
Only just add:
Removed them now.
This is the current config
interface BRI0/0/0
no ip address
show isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0/0/0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 116, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
ISDN BRI0/0/1 interface
dsl 1, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
Active dsl 1 CCBs = 0
Total Allocated ISDN CCBs = 0
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT
PORT
2 voip up up 2.. 0 syst ipv4:10.1.0.9
3 voip up up 3.. 0 syst ipv4:10.1.0.100
9 pots up up 9.T 0 up
0/1/0
8 pots up up 8.T 0 down
0/0/0
20001 pots up up 101$ 0
50/0/1
20002 pots up up 102$ 0
50/0/2
20003 pots up up 103$ 0
50/0/3
20004 pots up up 104$ 0
50/0/4
martinbuffleo Thu, 04/19/2007 - 03:58
Just tried a test call and it allowed an out going call? all a bit strange.
Now when I try and dial in I get told "the call will be disconnected"
I hoping that the Auto attendant will answer so I can dial an extension in.
Aaron Harrison Thu, 04/19/2007 - 05:02
Outgoing calls are working as you have corrected your ISDN interface configuration.
If the interface isn't up (which it wouldn't have been before you removed those commands) you won't get calls either way.
Re: inbound calls, start by doing a debug isdn q931 and placing a call in. This should reveal what numbers are being presented by BT.
Aaron
Please rate helpful posts...
