dmgtd log child process status ?
Answered Question
Apr 19th, 2007
Hi to all!
is it possible monitoring all ciscoworks process on windows machine, and forward a syslog messages (ex. "process down") to another manger like CIC?
In the syslog.log I cannot retrive this information. I have to set the log level.
There is another log file where the dmgtd daemon writes its messages?
There is a configuration file about this daemon?
thanks a lot
Leonardo
Correct Answer by Joe Clarke about 9 years 11 months ago
The syslog.log is written to by the CWCS Syslog service (crmlog.exe). However, these messages are not proper device syslog messages, and will be counted as Invalid messages by SyslogCollector. You will not be able to create Automated Actions for them. Instead, you will need to write your own application to read the dmgtd messages from syslog.log, and forward them were you want them to go.
Overall Rating: 4 (2 ratings)
Joe Clarke Thu, 04/19/2007 - 05:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The syslog.log will contain information about daemons being stopped and started by default. These messages are written to syslog.log via syslog to 127.0.0.1 on udp/514. These messages are intercepted by our syslog daemon, crmlog, and written out to the syslog message file (which is syslog.log by default).
A sample daemon startup message is:
dmgtd[1552]: 3007(I): Started application (ConfigMgmtServer ...
A sample daemon stop message is:
dmgtd[1552]: 3017: Application (ConfigMgmtServer, pid=3260080) stopped by request.
It would be up to you to parse this file, and forward the messages on to CIC.
Leonardo Roberto Thu, 04/19/2007 - 07:32
ok Jclarke.. thanks it's very helpful, but.. which cw process write on syslog.log file?
I can configure an automatic action, like done for devices, to capture a specific string inside the syslog.log file?
TKS
Leonardo
Correct Answer
Joe Clarke Thu, 04/19/2007 - 07:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
