E1 PRI
Apr 19th, 2007
Is this configuration correct for a data transfer from an E1 PRI
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial1/0:15
ip address 192.168.150.34 255.255.255.224
no cdp enable
encapsulation ppp
dialer idle-timeout 119
dialer string xxxxxx
dialer-group 1
isdn switch-type primary-net5
isdn point-to-point-setup
ppp authentication chap pap callin
ppp chap hostname yyyyyyyy
ppp chap password zzzzzz
dialer-list 1 protocol ip permit
Wilson Samuel Thu, 04/19/2007 - 10:33
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
Hey,
One question, if you want the entire 30 Channels to be dialed in simultaneously to the same destination why not use it as a E-1 rather than E-1 PRI.
I mean what is the need of PRI, if you can manage the same show with Channelized E-1 or E-1.
Otherwise in this config, I guess it should be fine.
