04-19-2007 06:16 AM - edited 03-05-2019 03:33 PM
Hi Guys,
What is the smallest Catalyst switch that supports NLB? Is it the 4500?
Thanks!
Jacques
04-19-2007 06:40 AM
If by network load balancing you mean Server Load Balancing (SLB), the Catalyst 6500 is the only Catalyst switch that supports this feature.
More information on SLB is available at http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121limit/121e/121e11/iosslb11.htm
04-19-2007 09:45 PM
Yes I apologize, I was actually referring to SLB.
Thanks for the info!
Jacques
04-19-2007 01:57 PM
NLB can use either multicast or unicast packets. So, pretty much any switch is capable of doing so.
Most of the caveats revolve around the affects of non-NLB hosts on that segment and/or the use of multiple switches.
NLB likes to hide its virtual MAC address from the switch, which causes the switch to broadcast in order to locate the appropriate MAC.
04-19-2007 03:19 PM
If you are specifically referring to MS NLB.
