CiscoIPPhonText newline character
Apr 19th, 2007
Hi!
It might be a simple solution, but i was wondering how to be able to send a new line character within a CiscoIPPhonText xml-file. Currently i'm using '\n'. This does work on a 7940 and 7960... but doesn't on my 7912. Is there an other character which i have to use instead that works fine for all the cisco phones?
thanks in advance!
Aaron Harrison Thu, 04/19/2007 - 07:33
  • Community Spotlight Award,
    Member's Choice, May 2015
Maybe \r\n
Aaron
stephan.steiner Thu, 04/19/2007 - 22:20
  • Silver, 250 points or more
When escaped sequences are interepreted differently across phone modes, always open a TAC case as it's a bug. I have a case open and a bug id for \t (tab).. it's not rendered the same on the 797x and the IP communicator.
