CCM5.1(b) integrate with CUE 2.3.4
Apr 19th, 2007
Hi, my CUE 2.3.4 integrate with CM4.X is work and fine. However when i try to integrate with CM 5.1b it got problem. It never integrate success. Would you please share you experience to me if you done it before thx!
Regards!
Daniel
Markus Schneider Wed, 04/25/2007 - 06:16
You mean it never registers, or you can't import users? What specifically doesn't work?
daniel_cheung Wed, 04/25/2007 - 19:00
Hi marschne,
Thanks for your reply, finally the problem solved. In CCM 5.1 we need to use application (JTAPI) user and need add the CTI Enable Group to that jtapi user.
Daniel Cheung
