CW LMS 2.6 software upgrades
Apr 19th, 2007
Using RME to upgrade a Cat 3750-48ts stack. The operation failed while tryint to move the new image from a temp file on the switch into flash. The error RME logged was because the user "cwuser" didn't exist on the switch. In our environment we use tacacs and have a CW account in tacacs for CW. Any thoughts?
jreekers Thu, 04/19/2007 - 12:44
Check your inetd.conf file to ensure tftp isn't commented-out. If you have initiated the transfer via RCP, ensure that you've configured in accordance with the instructions shown here:
Something else that might be useful is to get a sniffer (or snoop) trace of the transaction to see what RME is using as logon credentials and how the 3750 is responding.
Any clues in:
/var/adm/CSCOpx/files/rme/jobs/swim/1569/sctb01aal1_telnet.log ?
Can you try the SWIM job without tacacs, and if so, is it successful? If you manually do the task (outside of RME), does that work?
as you can see (by the fact I'm kind of all over the place here), this error is somewhat generic in nature, so there are a lot of things to check.
