Loading Balacing on Router
Apr 19th, 2007
I have two links of internet coming from diferents TELCO companies. Can I dritibuted my traffic on these links using 70% of bandwith and 30%?
Witch protocol or feature my router must perform to reach that. What other ways i can do this?
Thank you
Overall Rating: 3 (1 ratings)
Wilson Samuel Thu, 04/19/2007 - 10:57
There are a couple of ways to achieve the same, I'm listing some of them as below:-
1. Buy a Radware device and it will take all the burden and you neednt do anything.
2. Run BGP and manage the traffic with the help of a device from FCP
3. Run GLBP and that will help to an extent.
HTH,
Wilson Samuel
Paolo Bevilacqua Mon, 04/23/2007 - 04:13
Actually there is no need for either BGP, PBR or radware to balance unequally, if you are suing NAT.
Just configure some selective supernet routes like 200.0.0.0 /7
And that will make a pseudo-balancing to work. It is up to you to find the right set of destinations that attains your goal of 30% on one link.
Hope this helps, if it does please rate this post!
