Wireless CAM table interaction
Apr 19th, 2007
I was asked this question, but do not know the answer. Any help would be appreciated. Thanks in advance.
Do you know how the AP interacts with the CAM Table on the switch that it's plugged into? Does it only hold the MAC address of the AP, or does it hold the MAC addresses of all the devices connected to the AP?
gmarogi Wed, 04/25/2007 - 07:27
  • Bronze, 100 points or more
The Switch will handle the AP the same way as it handles other devices connected to it. In this case it will hold the MAC address of the AP which is connected to the port.
Trending Topics - Security & Network
