04-19-2007 11:22 AM - edited 03-11-2019 03:02 AM
Dear friends,
I'm having a issue with my PIX 515E. I'm trying to connect to a external FTP server from a host located on my inside network. The problem is I can connect and authenticate, but no commands work. I got "Invalid Port Command".
I tried both with "ftp mode passive" and "no ftp mode passive", with no results. What could be happening?
Mauricio
04-19-2007 12:32 PM
Did you check your global_policy map? make sure that inspect ftp is listed. This could well be the configuration on the other side. you can check from another location as well.
04-19-2007 12:50 PM
Etienne,
Yes. My configuration has "inspect ftp" and the problem happens with any FTP site. There's no problem of connecting from a Linux box with a DSL access located besides my firewall. So, the problem is PIX. What could be?
Mauricio
04-19-2007 12:54 PM
could you post your configuration? and also try to capture a syslog output when trying to access the ftp site.
04-20-2007 04:52 AM
Hi Mauri,
i had similar kind of issue with what u hav pointed out, but i end up with simple solution, i had cisco ASA 5510, in that there is a option called allowing the passive ftp mode, i just enabled that & it started working, so try the same in PIX, i tried using ASDM.
hope this helps.
rate this post if satisfied.
04-20-2007 05:11 AM
Hi, friend,
I already have tested this. I put it on my original post. I appreciate the help anyway. I guess there is a bug in my version, but I'm needing a correct answer to solve this.
Mauricio
04-20-2007 05:39 AM
what do you see in your syslog? do you mind posting the config, you can remove relevant IP information.
