WCS reports different number of wlans
Apr 19th, 2007
I have a strange problem. Under Monitor/devices/Access Points: I can search for an access point I have been having problems with. When I click on the B/G radio, the next page indicates three WLANs. HOWEVER, under the Configure/Access Point menu, only the two SSIDs I want are shown. I performed a reset on the AP. That did not work, so I performed a Clear Config. That did not work either. I shut the port and re-enabled it. When I run a network scan with Netstumbler or even just a laptop, I have four 1131AGs that broadcast an SSID I do not want broadcast. Any advice is appreciated.
irisrios Wed, 04/25/2007 - 10:16
How many WLAN do you see on the controller. Sometimes what can happen is, if the WLC and the WCS are not synchronized, the parameters may show differently on the WCS and the WLC. Make sure you have synchronized the WLC and WCS.
Trending Topics - Security & Network
