Brandon Buffin Thu, 04/19/2007 - 12:22
  • Purple, 4500 points or more
Do the following:
conf t
telephony-service
max-ephones ?
After typing ?, you should (1-X) where X is the maximum phones the system will currently support.
Hope this helps. If so, please rate the post.
Brandon
yhab_dataconsult Thu, 04/19/2007 - 12:39
Dear Brandon,
Actuly I have an issue with my CCME and I am not sure if it licence issue or configuration issue.
I am unable to rigester more than 24 phones on my 2852 even after entring "max-ephones 96" in the telephony-service .
atthced is copy of my runnig config.
Rob Huffman Thu, 04/19/2007 - 12:26
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Yousif,
Just to add a note to Brandons great info. CME Licensing is Platform Specific. Have a look at the following;
Maximum Total IP Phones (Platform Specific)
Cisco 2801
24 IP Phones
Cisco 2811
36 IP Phones
Cisco 2821
48 IP Phones
Cisco 2851
96 IP Phones
Cisco 3825
168 IP Phones
Cisco 3845
240 IP Phones
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a00807aae21.html
Hope this helps!
Rob
Edit: Brandon, please keep in mind that I flunked Typing 10 (I can't keep up :)
rh
gustavo001 Thu, 11/22/2007 - 14:01
Hello
I have got the same problem.
If i Have a 2801, how i can get reister more than 24 phones?
Brandon Buffin Mon, 11/26/2007 - 09:49
You cannot currently register more than 24 phones to a 2801.
Brandon
paolo bevilacqua Mon, 11/26/2007 - 09:55
  • Hall of Fame,
    Founding Member
You can register 30. This is because the real limits are a little higher than the official ones.
Brandon Buffin Mon, 11/26/2007 - 10:04
Good point. However, I think you'll only get support for 24.
Brandon
AJAZ NAWAZ Tue, 09/30/2008 - 06:25
  • Silver, 250 points or more
Hi Rob,
The link is not happening, do you know where it's been moved by any chance please...?
best regards
Ajaz
