NAT Traffic on Pix 515E (6.3.5) before Tunnel
Apr 19th, 2007
I have several clients using Pix Tunnels for site to site connections. I have one client who cannot route my internal network address space do to an overlap issue. I have tried to setup the nat, but the traffic is not changing to the NAT address.
Here are the entry's I used (the tunnel is working):
access-list outside_cryptomap_1400 permit ip host 64.x.x.5 142.x.x.86
access-list inside-outbound_nat3_acl permit ip 142.x.x.86
nat (inside) 3 access-list inside-outbound_nat3_acl
global (outside) 3 64.x.x.5
Any help would be appriciated!
scoutert24 Fri, 04/20/2007 - 05:37
This did not work, my problem is that my Nat ACL is getting Hits, but that is where it looks like the traffic stops.
Here is my Configs:
access-list inside-outbound_nat3_acl permit ip 10.x.x.0 142.x.x.86
crypto map outside_map 1400 ipsec-isakmp
crypto map outside_map 1400 match address outside_cryptomap_1400
crypto map outside_map 1400 set peer 199.x.x.23
crypto map outside_map 1400 set transform-set ESP-3DES-MD5
crypto map outside_map 1400 interface outside
isakmp policy 1400 authentication pre-share
isakmp policy 1400 encryption 3des
isakmp policy 1400 hash md5
isakmp policy 1400 group 2
isakmp policy 1400 lifetime 86400
Any other ideas?
srue Fri, 04/20/2007 - 05:45
have you done any debugging or do you have any logs that you can post?
scoutert24 Fri, 04/20/2007 - 10:33
I have just been watching counts on access lists, do you have any other ideas on how to debug the issue?
I just started picking up the Network devices at my company, since our last Network Engineer moved on.
Attached, working configuration of policy NAT VPN in my lab. Thing to note:
If there's another IPSec tunnel that uses NAT exemption, there will be a "nat (inside) 0 access-list ..." line in the existing configuration.
The access-list this references needs a deny added to it that specifies any traffic from the LAN side going to the peer inside subnet is ignored, otherwise the NAT will not happen.
Hope this helps!
