Answering Incoming Calls on FXO ports
Answered Question
Apr 19th, 2007
2821 H.323 Gateway with VIC2-2FXO card, PVDM2-32.
I can do outbound calls just fine, but inbound calls are not working. It looks like the FXO port answers the calls, but then it is dropped.
From debugging the dial-peers, I see the call come in but it looks like the calling number is getting stripped. What am I missing in my config?
voice-port 0/1/0
trunk-group POTS 1
timing hookflash-out 500
voice-port 0/1/1
trunk-group POTS 2
dial-peer voice 1 pots
trunkgroup POTS
incoming called-number .
direct-inward-dial
dial-peer voice 100 pots
trunkgroup POTS
destination-pattern ^1[2-9]..[2-9]......$
dial-peer voice 400 voip
destination-pattern ^425555....$
codec g711ulaw
session target ipv4:1.2.3.4
dtmf-relay h245-alphanumeric
no vad
#debug voip dialpeer all
Apr 19 21:02:17.904: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x4621F068,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_PORT;
Result=NO_MATCH(-1) After All Match Rules Attempt
Apr 19 21:02:17.904: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:[email protected]
Correct Answer by Paolo Bevilacqua about 9 years 9 months ago
Hi Jonny,
when you have FXO without caller-id active, both calling and caller number are empty as you can see. Since you have no DID, called number is also empty and won't match any "incoming calling-number". So you can either give dialtone to calls, or direct all call to a number of your choice using "connection plar".
hope this helps, please rate post if it does!
Overall Rating: 5 (2 ratings)
Correct Answer
Paolo Bevilacqua Thu, 04/19/2007 - 13:18
Hi Jonny,
johnnylingo Thu, 04/19/2007 - 13:33
Interesting...so if the POTS line does not have caller ID service, then then called number field will always be empty and I must use PLAR to receive the call?
Paolo Bevilacqua Thu, 04/19/2007 - 13:46
Hmm.. more exactly, if no caller-id, no calling number, but in any case, never called number.
So you can to override caller-id with "station number", that will give you at least calling number (always the same), that in turn you can use for sophisticated incoming DP setting using "answer-address".
Confused enough ? :)
johnnylingo Thu, 04/19/2007 - 16:15
Yes, I had played with "station-id number" and saw that actually modified the Calling number, which was weird. I'm just trying to set the Called Number.
Do you have an example of using "answer-address"? That's a new one to me.
Paolo Bevilacqua Thu, 04/19/2007 - 16:39
Sure. With working caller-id, send calls from certain area codes to hunt-group 100:
voice-port 0/0
cptone US
caller-id enable
answer-address 805........
translation-profile incoming to100
voice translation-profile to100
translate called 100
voice translation-rule 100
rule 1 // /100/
ephone-hunt 1 sequential
pilot 100
list ...
Attach an application to certain FXS ports:
voice-port x/y
station number 80
dial-peer voice 50 pots
application myapp
answer-address 80
...There are more :)
johnnylingo Tue, 04/24/2007 - 16:25
> so you can either give dialtone to calls, or direct all call to a number of your choice using "connection plar".
Providing dialtone is bad since the caller can then use it for toll fraud, and unfortunately I've found these lines get about 3X a day each from Telemarketers, so I doubt that PLAR is a good option for us.
Any way I can just reject the call, i.e. send a busy back?
Paolo Bevilacqua Wed, 04/25/2007 - 01:32
With FXO, when the lines is free, either you take the call, or don't. There is no ptocol to reject.
So if you want to fight telemarketers using FXO, your only option is to get caller-id, and see if you can find a pattern of caller-id or missing thereof to direct their calls to a message. At the same time you will loose the calls from all the people that has blocked caller-id or is calling from out-of area, as often caller-id doesn't work in these cases.
