Different BGP output in show run
Apr 19th, 2007
  • Blue, 1500 points or more
Hi All,
I have these two 3745 identical router. RouterA has existing config while RouterB has no config. Both has 12.3(21) Enterprise Plus IOS, I upgrade them to 12.4(10b) Advanced Enterprise. When I execute "show run" in RouterA, the BGP configuration part shows the same when it has the old IOS after reboot. However, when I paste the config to RouterB, the BGP configuration part shows different. Why is it so?
RouterA BGP config after upgrading from 12.3(21) Enterprise Plus IOS to 12.4(10b) Advanced Enterprise and reboot.
router bgp 1
no synchronization
bgp router-id 192.168.160.252
no bgp fast-external-fallover
bgp log-neighbor-changes
network 192.168.160.0 mask 255.255.240.0
aggregate-address 192.168.160.0 255.255.240.0 summary-only
neighbor 192.168.160.253 remote-as 1
neighbor 192.168.160.253 password 7 -secret-
neighbor 192.168.160.253 update-source Loopback0
neighbor 192.168.160.253 version 4
neighbor 192.168.160.253 next-hop-self
neighbor 192.168.160.253 soft-reconfiguration inbound
neighbor 192.168.160.253 prefix-list bogons in
neighbor 192.168.160.254 remote-as 1
neighbor 192.168.160.254 password 7 -secret-
neighbor 192.168.160.254 update-source Loopback0
neighbor 192.168.160.254 version 4
neighbor 192.168.160.254 next-hop-self
neighbor 192.168.160.254 soft-reconfiguration inbound
neighbor 192.168.160.254 prefix-list bogons in
neighbor 192.168.41.153 remote-as 2
neighbor 192.168.41.153 description BGP with ISP-A
neighbor 192.168.41.153 password 7 -secret-
neighbor 192.168.41.153 version 4
neighbor 192.168.41.153 soft-reconfiguration inbound
neighbor 192.168.41.153 prefix-list bogons in
neighbor 192.168.41.153 filter-list 1 out
no auto-summary
RouterB BGP config after upgrading from 12.3(21) Enterprise Plus IOS to 12.4(10b) Advanced Enterprise, reboot, and paste RouterA config.
router bgp 1
maximum-paths 2
address-family ipv4
neighbor 192.168.160.253 activate
neighbor 192.168.160.254 activate
neighbor 192.168.41.153 activate
maximum-paths 2
no auto-summary
no synchronization
exit-address-family
Overall Rating: 3 (1 ratings)
Harold Ritter Thu, 04/19/2007 - 19:33
  • Cisco Employee,
RouterB shows the new MBGP cli format. I'm not sure why it upgraded the configuration by default. You usually need to enter the "bgp upgrade-cli" command under "router bgp" for the upgrade to take place.
Can you provide a "show ver" from both routers.
Hope this helps,
Danilo Dy Thu, 04/19/2007 - 19:57
Hi Harold,
Thank you for your reply. Similar symptoms happen when I paste RouterA config to 3845 router with 12.4(10b) Adv Ent IOS. Here is the "sh ver" output from RouterA and RouterB. BTW, I don't see "bgp upgrade-cli" command option under "router bgp".
RouterA#sh ver
Cisco IOS Software, 3700 Software (C3745-ADVENTERPRISEK9-M), Version 12.4(10b),
RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 19-Jan-07 19:16 by prod_rel_team
ROM: System Bootstrap, Version 12.3(6r) [cmong 6r], RELEASE SOFTWARE (fc1)
RouterA uptime is 1 week, 1 day, 8 hours, 44 minutes
System returned to ROM by reload at 08:02:31 SG Fri Mar 1 2002
System image file is "flash:c3745-adventerprisek9-mz.124-10b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 3745 (R7000) processor (revision 2.0) with 499712K/18432K bytes of memory.
Processor board ID JPE071611NP
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
4 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of NVRAM.
125184K bytes of ATA System CompactFlash (Read/Write)
RouterA#
RouterB#sh ver
RouterB uptime is 1 hour, 50 minutes
System returned to ROM by reload at 08:41:49 SG Fri Mar 1 2002
[email protected].
Cisco 3745 (R7000) processor (revision 2.0) with 243712K/18432K bytes of memory.
Processor board ID JPE071611NQ
RouterB#
