how long should it take to setup the following:
Apr 19th, 2007
Hi all, Im somewhat new to VoIP. Id like a general idea from you guys on how long it should take to setup completely the following:
1 CallManager
1 CallManager Express
1 Unity Express
1 SRST remote router
Thanks.
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Fri, 04/20/2007 - 04:31
Assume is not too big a site and customer makes no strange requests.
Experienced person: 1 day CM, 1/2 day CME, 2 hrs CUE, 2 Hrs SRST. The latter actually takes longer because it must be fully tested and usually that can be done only at funny hours, else users will think what is just installed is broken already.
Unexperienced: whatever it takes and good luck.
