Failover VoIP to PSTN dial-peer configuration
Apr 19th, 2007
I have a CME with a SIP trunk connected to a PBX that allows 4 digit dialing over the WAN. If the WAN goes down I would like to translate the 4 digit number to the E.164 number and then re-route the calls to the PSTN. If the remote PBX extensions are 5xxx and their DID?s are 1-212-555-5xxx will the following configuration work?
dial-peer voice 1 voip
description SIP trunk to PBX
preference 1
destination-pattern 5...
session protocol sipv2
session target ipv4:10.10.10.10
no vad
dial-peer voice 100 pots
description Alternate for 4-digit calls
preference 2
prefix 1212555
port 1/0
Also will this work with CAC (using call threshold commands)?
Overall Rating: 4 (1 ratings)
rkandah Thu, 04/19/2007 - 20:05
Hi Mike,
You will need to modify your prefix to:
12125555
otherwise the number will go out as 1212555000
Rami
mike85719 Thu, 04/19/2007 - 20:45
Thanks for the help! I see what you mean about changing the prefix
Just curious...could I also fix the dial peer I origianlly posted by adding the command "forward-digits 11"?
