Cisco 827 NAT + Access server inside problem
I have a question about a NAT translation to a server in the inside network.
This command is added to de configuration:
ip nat inside source static tcp 3389 interface BVI1 3389
Is does not work to connect from the internet to de server on 3389 (RDP). I Have no accesslist on the interface`s.
If i use: sh ip nat translation then i see that inside global is natted to inside local
I hope that somebody can helping or can tell my how to debug this problem.
spremkumar Thu, 04/19/2007 - 23:12
AFAIK its better to have and static ip on the bvi interface which can be then mapped to the inside address.
I don't think at present you will be able to do RDP without checking out the ip address recieved out on the bvi interface.
If you can get a static ip address assigned to DVI then you can redo the mapping accordingly.
