Play audio file to IP Phone
Apr 19th, 2007
Hi, this time i have another issue to need your help. I'm trying to develop a new service that play an audio file to user. If that's mp3 file, it's great.
Thank you for your helps.
msabir Mon, 04/23/2007 - 09:35
  • Bronze, 100 points or more
You can transmit MP3 is G.711.ULAW from your server and use RTPRx URI on the phone to listen to it.
support02 Thu, 05/03/2007 - 01:32
do u have any documentation about tp do this..it so simple?
stephan.steiner Mon, 05/07/2007 - 03:37
  • Silver, 250 points or more
the only freely available app out there is the g.711 streamer I have posted in this forum.. a search will turn it up. There's strictly no documentation available - those that have apps that do it all and are easy to use want to make money with it.
