can?t see the VLANID in ethernetpacket with sniffer
Apr 20th, 2007
hi,
i have the following setup:
two switches 2960 connected together over a trunked connection (802.1q)
i have two vlans configured in the switch:
vlan 1 (default) and vlan2.
i have a sniffer connected and i am mirroring the port where the two switches are connected to the sniffer.
there is a router connected on a port - this port is an access-port in vlan 2.
if i do a ping from this router over the switch-switch connection, i am not able to see the vlanid in the packet?
the pingsize is only 100 byte
i need this investigation for analysing the cos fields in the vlan-header
thank - any idea ???
Overall Rating: 4 (2 ratings)
royalblues Fri, 04/20/2007 - 00:29
  • Green, 3000 points or more
Just to ensure you are mirroring the trunk port connection between the switch
cos bytes will be carried only on the trunk links
better would be to put 2 desktops in 2 different vlans and place them across the 2 switches and ping them... you should see the cos bytes
Narayan
rabeder Fri, 04/20/2007 - 02:21
hi,
i opened the switch-switch connection and inserted a hub - so i looked at the right frame - between the two switches.
here you can see the relevant switchkonfig:
interface FastEthernet0/1
switchport access vlan 2
switchport mode access
no logging event link-status
mls qos trust dscp
spanning-tree portfast
interface FastEthernet0/3
switchport access vlan 3
interface FastEthernet0/24
switchport trunk allowed vlan 1-3,10,1002-1005
switchport mode trunk
on port 0/1 there is the enddevice connected
port 0/24 is the switch-to-switch interlink (over a hub), where i do the sniffering
the enddevice is a router, connected to port 0/1 wich the following config:
interface FastEthernet3/1
description to filiale
bandwidth 100000
ip address 30.30.30.1 255.255.255.0
duplex auto
speed auto
max-reserved-bandwidth 100
the config from other switch:
interface GigabitEthernet0/1
interface GigabitEthernet0/24
switchport trunk allowed vlan 1,2,10,1002-1005
fakt is that i can?t see the vlan id on the interswitchlink - i do not know why !
ankbhasi Fri, 04/20/2007 - 01:04
  • Cisco Employee,
Hi Raber,
As Narayan updated I believe you are sniffing the trunk interface?
Also can you post teh output of
"sh run | in monitor"
Ankur
rabeder Fri, 04/20/2007 - 02:22
hi,
mls qos trust dscp
bandwidth 100000
duplex auto
speed auto
