Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928647members
1242354discussions
Community Activity
Resolved! Recording Jabber - Overlapping Voices
Hello, I'm having this situation:In the call center we have PCs with softphones installed (Jabber) that replicate the traffic to a recorder in another site.Randomly, we are seeing high levels of Jitter in the flow that is replicated to the communicat...
Andriel by Level 1
  • 2883 Views
  • 10 replies
How Do I Really Get Through To 𝗤𝗮𝘁𝗮𝗿 𝗔𝗶𝗿𝘄𝗮𝘆𝘀? #USATOLLFREE
핳햔햜 행햔 해 했햔햓햓햊했햙 햙햔 헤헮혁헮헿 헔헶헿현헮혆혀? +ퟭ-ퟱퟳퟯ-ퟲퟬퟲ-ퟰퟱퟳퟳ헤헮혁헮헿 퓐irlines's dedicated customer care team is always ready to assist you. Passengers can Call 헤헮혁헮헿 퓐irlines by dialling the (24x7) Phone Number at ퟭ-ퟱퟳퟯ-헤헮혁헮헿 퓐irlines +ퟭ-ퟱퟳퟯ-ퟲퟬퟲ-ퟰퟱퟳퟳ✍ (OTA) or +ퟭ...
How Do I Connect Live Person To KLM? Contact Now™ USA】
How Do I Connect Live Person To KLM? Contact Now™ USA】퓣퓸 퓬퓸퓷퓷퓮퓬퓽 with KLM 퐀퐢퐫퐥퐢퐧퐞퐬 +1-805-327-7444�, explore multiple ch헔nnels like their website, mobile 헔pp, or customer service +1-805-327-7444� hotline 헔t (UK line). Booking 헙헹헶헴헵혁s, m헔n헔ging reserv...
How can I speak with a live person at 𝗤𝗮𝘁𝗮𝗿 𝗔𝗶𝗿𝘄𝗮𝘆𝘀 #USA
Mitel - DHCP Discovery
Hi, I have a Mitel 5312 phone plugged into a switchport configured for ISE but when it boots up it gets stuck on DHCP Discovery. If I put the port to authentication open then it goes through and boots up as normal.The logs all look ok but I can't see...
Catalyst3550:ACL設定のインバウンド/アウトバウンドの適用先について
L3スイッチのACL設定についての質問です。accecc-listコマンドで番号付きアクセスリストを作成し、(例:access-list 100 permit icmp 1.1.1.1 0.0.0.0 any echo)作成したVLAN(1.1.1.254/24)にアクセスリストを付けたいです。このとき、in/out を指定したいのですが、(ip access-group 100 in/out)このインバウンド/アウトバウンドというのは、何視点でのイン/アウトなのでしょうか?ポート→VLAN→L...
Yuukoide by Level 1
  • 0 Views
  • 0 replies
Trustsec Network Authorization not Working
Hi All,I am newly building trustsec in my environment,trying to add one of the switch under trustsec. Have configured Trustsec settings and COA on the ISE for the switch and added the appropriate aaa commands , radius servers and cts commands.But sti...
BD Subnet advertised over L3out
Hello when a BD subnet is advertised over an OSPF L3out, i'm seeing tha subnet as E2 external route with metric 20 on the router connectd to BL (VPC link). Why the subnet is shown as external and not internal OSPF route? Why the metric is 20 ? Regard...
AirBorn by Level 1
  • 4 Views
  • 0 replies
Help with extended access list
So I've been working on my project and I've implemented vlans nad also router stick.Now I want to block connections between vlans that are not same with extended access list but something does not work..Here are the commands that I've writtenip acces...
AP9115axi
Hi ,I am facing one issue. AP9115AXI (access point) acquired IP address from DHCP. Confirmed with ARP table on switch.But  the command sh cdp nei detail - doesn't show IP address of AP. AP not yet associated to WLC.Any suggestion?With Regards,Ravindr...
ACL configure
I want to create an ACL on Cisco to prevent one network from communicating with others except for the internet. Can you help?
cyberpea by Level 1
  • 89 Views
  • 4 replies
  • 1 Helpful votes
