Cisco 803 and ISDN
Apr 20th, 2007
Hello everybody!
I must configure a CISCO 803 for it to comunicate with a CISCO CL3620 via ISDN.
Both routers have different IPs. The CL3620 is connected to an primary ISDN line, while the 803 is connected to a Basic ISDN line.
If I ping from the 3620 to the 803, I can see the orange light (ISDN) in the front pannel of the 803, and the ISDN channel activates and I receive the replies. But if I ping from the 803 to the 3620, the channel doesn't activate.
I paste the configuration of the 803, in case you can help me out.
Thanks in advance!
803 config.
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname router803
boot-start-marker
boot-end-marker
enable secret xxx
username xxx password xxx
aaa new-model
aaa authentication login default local
aaa authentication ppp default if-needed local
aaa session-id common
ip subnet-zero
no ip source-route
ip domain name domain.es
ip name-server x.x.x.x
isdn switch-type basic-net3 /* I'm from Spain) */
interface Ethernet0
ip address x.x.x.x 255.255.255.0
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
ppp authentication chap
interface Dialer1
ip unnumbered Ethernet0
encapsulation ppp
dialer pool 1
dialer remote-name 3620
dialer idle-timeout 300
dialer string 93XXXXXXX
dialer-group 1
compress stac
no cdp enable
ppp chap hostname router803
ppp chap password xxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 1.0.0.0 255.0.0.0 Dialer1 permanent
ip http server
dialer-list 1 protocol ip permit
line con 0
spremkumar Fri, 04/20/2007 - 02:19
  • Red, 2250 points or more
Do post out show isdn active and show isdn status ?
regds
clabsaclabsa Fri, 04/20/2007 - 02:23
Here there are:
router#show isdn active
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
router#show isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 65, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
spremkumar Fri, 04/20/2007 - 02:31
Can you change the ip addressing scheme which you are using currently out there ?
can you assign a /30 ip address on both the ends of your dialer so that you can avoid ip unnumbered command from the dialer.
Also would like know the idea behind having one more static route in addition to the default route..
can you also get the logs once you enable debug isdn q931 with logging or term mon ??
regds
clabsaclabsa Fri, 04/20/2007 - 02:47
"Can you change the ip addressing scheme which you are using currently out there ?
can you assign a /30 ip address on both the ends of your dialer so that you can avoid ip unnumbered command from the dialer."
I can't change this scheme since it has been used during months in my company. What I can do is try to remove the 'ip unnumbered' command. Just tried it and doesn't work yet.
"Also would like know the idea behind having one more static route in addition to the default route.. "
Yes, maybe it is unnecessary, but I'm a little newbie. One is to allow traffic to the internet, and the other one is to allow traffic to the LAN in the offices.
"can you also get the logs once you enable debug isdn q931 with logging or term mon ??"
OK. I activate the debug, try to ping the 3620 and I get the following for each ping:
00:01:17: ISDN BR0 Q931: TX -> SETUP pd = 8 callref = 0x01
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Called Party Number i = 0x80, '93XXXXXXX'
Plan:Unknown, Type:Unknown
00:01:17: ISDN BR0 Q931: RX <- CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x8A.
00:01:18: ISDN BR0 Q931: RX <- DISCONNECT pd = 8 callref = 0x81
Cause i = 0x8095 - Call rejected
Display i = 'Call is rejected'
00:01:18: ISDN BR0 Q931: TX -> RELEASE pd = 8 callref = 0x01
00:01:18: ISDN BR0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x81
Thanks!
spremkumar Fri, 04/20/2007 - 03:19
Can you post the config of the 3620 router too ?
Can you also get the debug details from 3620 router ?
But before doing debug/logging do make sure that your box is not loaded fully,over load may cause router to reboot.
regds
clabsaclabsa Fri, 04/20/2007 - 03:27
Here it is:
version 12.2
hostname 3620
aaa new-model
aaa authentication ppp default local
aaa authentication ppp DIALIN group radius
aaa authorization network default local
aaa authorization network DIALIN group radius
enable secret xxx
isdn switch-type primary-net5
chat-script offhook "" "ATH1" OK
chat-script callback ABORT ERROR ABORT BUSY "" "ATZ" OK "AT" OK "ATDT \T" TIMEOUT 60 CONNECT \c
controller E1 0/0
pri-group timeslots 1-31
interface FastEthernet0/0
ip address 1.X.X.X 255.0.0.0
ip nat inside
duplex auto
speed auto
interface Serial0/0:15
no ip address
encapsulation ppp
dialer pool-member 28 max-link 28
isdn incoming-voice modem
no cdp enable
interface Group-Async1
description Template a aplicar a totes les interfaces async, com els modems
ip unnumbered FastEthernet0/0
encapsulation ppp
async mode dedicated
peer default ip address pool DIALIN_POOL
compress mppc
ppp max-bad-auth 3
ppp callback accept
ppp authentication ms-chap chap DIALIN
ppp authorization DIALIN
group-range 33 38
interface Dialer1
encapsulation ppp
dialer pool 28
dialer remote-name router803
dialer snapshot
dialer-group 1
snapshot server 5
compress stac
no cdp enable
ip local pool DIALIN_POOL 1.0.6.1 1.0.6.6
ip nat translation timeout 259200
ip nat pool NAT_EXTERN 10.99.99.2 10.99.99.254 netmask 255.255.255.0
ip nat inside source list 10 pool NAT_EXTERN
ip classless
ip route X.X.X.X 255.255.255.0 Dialer1 permanent
logging trap warnings
snmp-server enable traps tty
line con 0
exec-timeout 0 0
line 33 38
script modem-off-hook offhook
script callback callback
modem InOut
line aux 0
line vty 0 4
transport input telnet
end
