restrict users access to change clients options
gmarogi Thu, 04/26/2007 - 08:28
Try this option: Making a Parameter Read Only option:
To make a parameter read-only so that the client user cannot change it within the VPN Client applications, precede the parameter name with an exclamation mark (!). This controls what the user can do within the VPN Client applications only. You cannot prevent someone from editing the global or .pcf file and removing the read-only designator.
Refer this link
