WebVpn
Apr 20th, 2007
Hi forum,
I'm unable to a access https webpages using clientless WEBVPN(configured on router) but able to access http webpages.
How can i access https webpages using clientless WEBVPN??
Ankur
rajbhatt Wed, 04/25/2007 - 04:13
Hi Ankur,
Have you checked url-list for https in the webvpn config .
They are correctly set .
What is the error u are getting ?
Raj
mittal.ankur Fri, 04/27/2007 - 03:19
Hi Raj!
'Url-list' command is there n correctly set. No error message is there. It seems to be the SSL-certificate issue.
Thanks for your response.
Ankur
