Feature "Web-Based Proxy Authentication" in Catalyst 6500s run IOS
Apr 20th, 2007
Hi all,
Is there any feature like "Web-Based Proxy Authentication" in catalyst 6500 run IOS?
I saw that in Catalyst 6500 running CatOS but in IOS. Can anyone show me the similar feature in IOS.
Thanks in advance,
Overall Rating: 4 (1 ratings)
Iain Fri, 04/20/2007 - 08:23
You need to check Feature Navigator.
When I do a search for these features "Firewall Feature Set" & "Firewall Authentication Proxy", I show that there are numerous Sups in the 6500 series which DO support both the features you're interested in.
Most of the images required are ADVANCED ENTERPRISE SERVICES level. So depending on your hardware you may require RAM upgrades to run them.
pls rate if helpful
Amit Singh Fri, 04/20/2007 - 10:00
"Web-Based Proxy Authentication" for users without 802.1x client is only supported on CtaOS at this point of time. We donot siupport that feature in cisco IOS at this point of time. This feature will be available on Cisco IOS shortly.
HTH,Please rate if it does.
-amit singh
