Multiple File Copy
Apr 20th, 2007
I am trying to copy multiple files from flash to a usb key. The issue isn't the media, its the proper command (if one exists). Is it possible to copy multiple files using one statment? For example:
copy flash: usbflash1:
It errors out and doesn't seem to like it.
If not possible natively, does anyone have a TCL script that can do this?
I am trying to come up with a solution to "image" a 2811 running CME (lots of config files, phone loads, etc.) by copying the flash onto a usb key.
Any advice would be appreciated.
Mike
Overall Rating: 5 (2 ratings)
Joe Clarke Fri, 04/20/2007 - 08:32
See this thread where I gave a sample TCL script to iterate over all files:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddcef70/2#selected_message
You can modify the code to perform a copy operation instead of just printing the file names out. For example:
set fileList [glob -directory flash: -nocomplain *]
foreach file $fileList {
copy flash:/$file usbflash1:/$file
Joe Clarke Fri, 04/20/2007 - 08:39
Actually, try:
copy $file usbflash1:
You may also want to set "file prompt quiet" in the config first so that you're not prompted for each response.
mlitka Fri, 04/20/2007 - 09:43
WOW. Worked like a charm. Thanks for that quick solution!!
mlitka Mon, 04/23/2007 - 12:16
How do you include subdirectories and the files they contain?
Joe Clarke Mon, 04/23/2007 - 12:20
You'll have to recurse by testing to see what type of file object you've encountered. So you'll need to test each object returned by glob with "file isdirectory". For each object that is a directory, you will need to perform the same glob operation on it.
mlitka Mon, 04/23/2007 - 12:21
OK. Now to tackle that :). An example would be awesome. :>
Joe Clarke Mon, 04/23/2007 - 13:07
This is untested, but something like:
proc copyDir { dir dest } {
set fileList [glob -directory $dir -nocomplain *]
if { [file isdirectory $file] } {
copyDir $file $dest
} else {
copy $file $dest
copyDir flash: usbflash1:
mlitka Mon, 05/07/2007 - 13:26
Thanks. Tried to run this but nothing happened.
Joe Clarke Mon, 05/07/2007 - 13:31
The key is the last line:
That sets thing in motion. The copyDir proc is just a function. If you don't execute it, nothing will happen. In the above example, "flash:" is the source and "usbflash1:" is the destination.
cablexpress Fri, 10/05/2007 - 08:24
I found this post and had the exact same question. I copied the following to a notepad
saved it as copy_files.tcl
Then TFTP to internal flash of router
I went into CLI and added the following
event manager applet copy_files
event none
then I trigger manually with event manager run copy_files
it says it's triggered but I must be doing something incorrectly.
Joe Clarke Fri, 10/05/2007 - 09:17
This is not an EEM policy, but a tclsh script. You need to run it using tclsh from exec mode:
tclsh flash:/copy_files.tcl
