Monitoring Hits on PIX
imranraheel
Is there any command or tool through which i can check which IP is hitting my pix from out side and from inside i want to check the sessions which are been established using my PIX 515e
srue
Level 7
Level 7
this should be available under the logging options, if you set the log level high enough. be careful, this will generate lots of output.
Collin Clark
You'll need something to parse the syslog files otherwise you'll be sifting through a bunch of stuff. I wrote a simple bash script, I can post it if you're interested in it.
opers13
Enable logging on your PIX, go to http://www.kiwisyslog.com and download Kiwi syslog server for free.
Kiwi Syslog Daemon is a freeware Syslog Daemon for Windows. It receives, filters, logs, displays and forwards Syslog messages and SNMP traps from hosts such as routers, switches, Unix hosts and any other syslog enabled device.
opers13
