Movian VPN client and Cisco PIX
boschrexroth
Our company has bought some HP iPAQs and we want to be able to connect them to our network via VPN.
We have a Cisco Pix running 7.1.4 and it is already configured to accept Cisco VPN clients.
I have read about the Movian client for the iPAQs.
Can anyone tell me where I can download it and if it will work with a PIX?
Is there anything special I have to do with the config to make it work?
Thanks.
acomiskey
Level 10
Level 10
I think it is now called antha vpn.
http://www.anthavpn.com/webmaker/portal/wmlink_360
Also check out bluefire, I have used this one with cisco ASA.
http://www.bluefiresecurity.com/products/vpn/
Apparently Bluefire does not support my iPAQ.
I tried anthavpn but it wouldn't connect an my trial license expired after 3 attempts.
Any other vendors anyone know of?
Thanks.
Ya, antha 3 attempt lock out is the worst idea ever.
Did you try the bluefire trial or did you just look on the supported devices list? I used a device which was not on the list. Is this WM5? If it is WM 2003 there is a separate download for 2003 Second Edition.
I also recommend Bluefire VPN. Works great with the VPN 2060. I'm running on WM5... I didn't see what your IpaQ was running, but they have many versions.
