IPM errors
Answered Question
Apr 20th, 2007
I cannot add a new collector to my IPM configuration. I get the error message:
AddCollErr
REASON: Response Timed Out
Recently I've stopped and deleted old collectors and targets. I only have 2 collectors running.
I'm using LMS 2.6, IPM 2.6 on a Windows 2003 Server.
Correct Answer by Joe Clarke about 10 years 1 week ago
While you can certainly reinitialize the IPM database with:
ipm dbclean
This may be as simple as a bad read-write community string (or SNMP credential) for the source device. You might try starting a sniffer trace filtering on all SNMP traffic to your source device when trying to add the collector, and see if anything obvious stands out.
Overall Rating: 5 (1 ratings)
jreekers Fri, 04/20/2007 - 10:52
  • Cisco Employee,
You might want to try this:
1. Stop all IPM processes.
2. Goto /etc
3. Modify the parameters in the ipm.env file -
IPM_SNMP_TIMEOUT=10
IPM_SNMP_RETRIES=5
4. Start all IPM processes
5. Retry to see if the problem still exists.
Hopefully increasing the timeouts help.
rdanevich Fri, 04/20/2007 - 12:51
No joy!
Is there a procedure to cleanse/rebuild the IPM database?
Correct Answer
Joe Clarke Fri, 04/20/2007 - 12:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
ipm dbclean
rdanevich Fri, 04/20/2007 - 23:11
Thanks Joe! That really did the trick. There've been so many changes over the last few months to the overall Topology of the network that I think re-initializing the IPM Database was the best option. Adding new devices and collectors is real quick now. Thank You I really appreciate the help and your quickness to respond to our posts on this Forum.
