RPR
alsayed
Hi!
on 4507r,2 sup:sup-wsx4515;i need to configure the RPR Mode;do i need to put the console into sup on slot 2 and configure the redandany mode(rpr) or it is done in the 1st sup on the slot 1 if all config its done form there.
10xs
5 Replies 5
ankbhasi
Hi Ali,
This will help you in configuring RPR on 4507R
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_12/config/rpr.htm#wp1097801
Supervisor engine redundancy is configured by default when a second supervisor engine is detected
Do read the section "Supervisor Engine Redundancy Guidelines and Restrictions"
Ankur
Hi Ankur!
Thanks a lot for ur reply.
Ali
Hi Devang,
Long time!! How are you!!
I believe what Ali is looking for is RPR operation betwen 2 supervisor engines which is route processor redundancy.
Ankur
Hello Devang!
Welcome Back;long Time Ya man;where have you been?
Ali
