Call Manager Attendant Console Issue
Answered Question
When a receptionist is logged off and has minimized the call manager application and a call comes to their phone the application pops up on their computer screen. Is there an option somewhere to change this option?
thanks
John
Correct Answer by Brandon Buffin about 10 years 3 months ago
Yes, there is a button in the lower right hand corner of the attendant console window that says "Click to activate console on new call" if you mouse over it. Click this button and it will toggle this feature.
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 5 (2 ratings)
Correct Answer
Brandon Buffin Fri, 04/20/2007 - 12:42
  • Purple, 4500 points or more
Brandon
Rob Huffman Fri, 04/20/2007 - 13:14
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi John,
To add a note to Brandons good info, you can also use this method to enable/disable "Pop to Top"
Note: To toggle the pop-to-top feature on and off, press Alt + P.
From this doc;
http://www.cisco.com/en/US/products/ps7282/products_user_guide_chapter09186a00806cfff5.html#wp1007405
Hope this helps!
Rob
