Re-using Avaya Headsets?
Answered Question
Apr 20th, 2007
I have a customer that wants to re-use a significant quantity of Avaya headsets with Cisco 7960 phones. The Avaya parts are:
1. bottom cable = 49323-04
2. head set = 49083-01
I have gtried a test with a 7960, but it doesn't quite work. If I plug it into the headset jack, I get no audio in either direction. If I plug it into the handset jack, I the headset can hear the remote end, but the headset mic doesn't seem to work.
Cisco documentation points me to:
http://cisco.getheadsets.com or http://vxicorp.com/cisco
The first link doesn't work, and the second link has no list of supported sets.
Any ideas on how to investigate this or change a cable to get this to work?
Thanks!
Correct Answer by Rob Huffman about 9 years 11 months ago
Hi Aaron,
The Avaya 49083-01 is a re-branded Plantronics Supra Monaural NC. If you order the Plantronics Part# (26716-01) for about US$12 you will be good to go :)
http://www.plantronics.com/canada/en_US/products/cat29880043/cat29880043/prod5210004
Plantronics Quick Disconnect to Modular Plug 10-Foot Coiled Cable (26716-01)
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 04/20/2007 - 17:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Aaron,
Hope this helps!
Rob
