SDM 2.4 and IPS V5
Answered Question
Apr 20th, 2007
Does V5 IPS not work with SDM? I get the message "IPS not supported" using IOS 12.4(11)T1. CLI show IPS working.
Correct Answer by ymzhang about 9 years 6 months ago
SDM need 12.4(11)T2 or later image to support IOS IPS in 5.x signature format due to some issues in IOS.
For 12.4(11)T1, the best option is to use CLI for now.
Also please refer
Overall Rating: 5 (1 ratings)
juan_m_12 Mon, 04/30/2007 - 17:20
hi, i got the same issue, with IOS c2800nm-advipservicesk9-mz.124-11.T1.bin image, i will need to read the full document mentionated above
scottyd Thu, 05/03/2007 - 14:04
Is anyone else having high memory issues when using ver 5? I have installed on a 1801 with 128 M memory. It only has 4 M free now. Is there a way to reduce the active signatures? I have disbaled some but the number of active is still at 338.
ymzhang Thu, 05/03/2007 - 15:26
you can use IOS IPS CLI to retire un-needed signatures.
ip ips signature-definition
signature 3307 0
retired true
Be sure to answer yes to the prompt when exiting the CLI configuration.
Do you want to accept these changes? [confirm]y
Once a signature is retired, it wont be compiled by IOS IPS.
jeremy_liao Tue, 07/24/2007 - 09:08
what is different between "retired ture/false" and "enabled ture/false", thanks
nicksmi Tue, 07/24/2007 - 10:41
When a signature is retired, it is no longer processed by the engine, saving memory.
When a signature is disabled, it is still processed by the engine, but will not display alerts when it is triggered.
