PIX 501 used to block part of subnet
Apr 20th, 2007
I have a PIX 501 with a single inside network of 192.168.0.1/24. I need to block all IPs above .128 from getting outside.
My question is this -- should I configure two internal networks of 192.168.0.0/25 and 192.168.0.129/25? Or, can I leave the single network of 192.168.0.0/24 and just implement a rule to Deny outbound from inside 192.168.0.129 255.255.255.128 ?
Overall Rating: 4 (1 ratings)
Jon Marshall Sat, 04/21/2007 - 05:43
No need to renumber your internal LAN.
As you say you can just use the second half of the subnet in the access-list on the pix ie.
access-list deny ip 192.168.0.128 255.255.255.128 any
access-list permit ip 192.168.0.0 255.255.255.128 any
Jon
