Clients not getting IP address from DHCP server through Tunnel interface.
Apr 20th, 2007
Could someone help me with this:
APs were able to get registered by WLSM but client can't get IP Adrresses from DHCP server through Tunnel interface on Sup 720. IP helper configured on Tunnel Interface.
Overall Rating: 4 (1 ratings)
malgorzata.oleszak Wed, 07/04/2007 - 00:18
I've got the same problem. I established 2 tunnels, one of them works fine, the second - I experinced the same problem with dhcp - clients can't get ip address through dhcp server located on switch or even helper address. Did you find any solution?
m_adetunji Wed, 07/04/2007 - 17:32
I was able to solve it in the end. I had an ACL on Core Switch blocking traffic from AP to/fro WLAN/WLSM Switch. The initial traffic goes through the AP's and access switch (authentication and broadcast) to WLAN/WLSM switch through Core, thereby blocking layer 3 traffic and not layer 2 (authentication).
You might need to check your radio on your client (a = 5. Ghz or b/g = 2.4Ghz) to see that it corresponds to what is configured on the AP.
dancampb Wed, 07/04/2007 - 09:36
  • Cisco Employee,
What often causes this issue is that the sup720 is missing the config "no ip dhcp snooping information option" in the global config.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
