04-20-2007 06:41 PM - edited 03-13-2019 04:05 PM
Hello everyone,
I gonna upgrade Unity3.1(6) to 4.0(5).
Before upgrading, I would like to check the Unity health status.
I run DBWalker without fixing automatically, got the following messages:
Menu key: 0
1226:(error) set to go to a missing call handler with an ObjectID={51293A53-66CD-439E-B0DD-19B889CA130A}
You can try reselecting the one key action on the 'caller input' page for this call handler or subscriber and saving to clear this issue
Menu key: 0
Menu key: 0
1226:(error) set to go to a missing call handler with an ObjectID={F4621EEF-7332-4AB7-9E15-525785EAFB02}
Menu key: 0
My questions are :
1. Any idea for those errors?
2. Should I run DBWalker again and fix these problems?
3. Any other tools/software to check Unity system health status?
Thank you for your reply.
Howard
04-21-2007 04:04 AM
Howard,
Go to the Caller Input page for the call handler or subscriber referenced by each error and click the 0 key. Make sure that this key points to a valid call handler and rerun DBwalker.
Brandon
04-22-2007 07:47 AM
Hi Howard,
Like Brandon correctly noted, these errors are very minor in nature and can be easily fixed. I have attached a really good Unity 3.x to 4.x upgrade doc that contains important steps required for this change;
Upgrading Cisco Unity 3.x Software to the Shipping Version
From this excellent Upgrade doc;
Hope this helps! And best of luck.
Rob
