upgrading firmware question
Answered Question
Apr 20th, 2007
Well, I have very little experience with the 6000 with a MSFC card in it, which is what I found out today that this switch has. My question is this: if I upgrade the switch CatOS firmware, do I have to upgrade the MSFC firmware as well?
Correct Answer by mohammedmahmoud about 10 years 1 month ago
Hi John,
CatOS image is used as the system software to run the Supervisor Engine on Catalyst 6500/6000 switches. If the optional MSFC is installed, a separate Cisco IOS Software image is used to run the MSFC (so no relation between both). This combination is called a Hybrid mode.
Did you think about converting the switch from CatOS to IOS --> Cisco IOS Software on both the Supervisor Engine and MSFC (Native): a single Cisco IOS Software image can be used as the system software to run both the Supervisor Engine and MSFC on Catalyst 6500/6000 switches.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008070f124.shtml
HTH, please rate if it does,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
Correct Answer
mohammedmahmoud Sat, 04/21/2007 - 02:04
  • Green, 3000 points or more
Hi John,
Mohammed Mahmoud.
