More info on Reporting in version 5
Apr 20th, 2007
We currently use mailflow to run end of month reports on top 10 domains our users are going to.
If I read correctly the documents for ver 5 says mailflow data is deleted when the upgrade occurs. and data no longer gets uploaded to mailflow.
Based on this I guess I should wait till the end of the month to do my upgrade so I can get April's report out.
Can anyone comment on this and your overall impressions of reporting in version 5?
Rayman_Jr Mon, 04/23/2007 - 12:37
Yes, the Mail Flow Monitor data from appliances will be wipe out but you still can generate top 10 domain reports from Mail Flow Central which continue working on ver 5 log files.
tminchin_ironport Mon, 04/23/2007 - 14:20
i used the MFC stuff for monthly reports - so as you suggest it was easier just to do an upgrade to 5.1 at 1am on the first day of the month.
