Mapping incoming ports to different NAT addresses on PIX
Apr 20th, 2007
Hello all
Can i use the extendable keyword on the pix firewall to map incoming ports to NAT private lan addresses? if yes, what is important to know before to do that. If not, how can i do that ?
Will be good if i will have any example
Thank you !
Patrick Iseli Sat, 04/21/2007 - 16:09
  • Gold, 750 points or more
This feature is called Port Address Translation or PAT.
All port that are connecting to your outside interface IP address are forwarded, translated, to an induviual inside private IP.
example:
access-list acl_out permit tcp any interface outside eq http
access-list acl_out permit tcp any interface outside eq smtp
access-group acl_out in interface outside
static (inside,outside) tcp interface http 192.168.1.10 http netmask 255.255.255.255 0 0
static (inside,outside) tcp interface smtp 192.168.1.23 smtp netmask 255.255.255.255 0 0
Reference:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/prod_configuration_examples_list.html
sincerely
Patrick
